closed loop..
Old Apr 2, 2010 | 10:23 PM
s1cab's Avatar
s1cab
Default closed loop..
just wondered if someone can explain this to me? thanks in advance
Old Apr 3, 2010 | 05:07 AM
JesseT's Avatar
JesseT
The air fuel ratio is being measured with an exhaust oxygen sensor to constantly correct the mixture.
Typically only active while cruising and idling.
This has been in all production cars since the catalytic converter was introduced. So, some old non-cat Fords didn't come with one right from the factory.
Old Apr 3, 2010 | 05:31 PM
s1cab's Avatar
s1cab
cheers !
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
`spotty
Sep 25, 2015 11:41 PM
pabloXR
Sep 21, 2015 12:42 PM
