Holset on zetec turbo..
Old Apr 1, 2010 | 07:41 AM
xtrmjks's Avatar
xtrmjks
Default Holset on zetec turbo..
I'm going to use Holset on my Zetec turbo. Read on the net, Holset's dont like high oil pressure and need oil feed restrictor...is this true??
Old Apr 1, 2010 | 08:20 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if it is a roller bearing turbo then probably true.
i wouldn't say a zetec is that high on pressure really, compared to my former alfa that would idle at 7BAR and peak at 9BAR of oil pressure.
roller bearing turbos don't need pressure to keep the shaft floating in the bearings like the wet float type.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
Russ Payne
Sep 25, 2015 08:29 PM
