3dr cossie ABS sensor..anyone???
Old Mar 31, 2010 | 03:48 PM
1374lee's Avatar
1374lee
Default 3dr cossie ABS sensor..anyone???
As above I need a front ABS sensor,Ford stated they are NLA but I think they are available for the sapp 2wd,not sure if they are the same or not?
Anyone know the answer here please?
Anyway I need a fron ABS sensor,anyone got one or know perhaps where I could get hold of one?
Not even 100% if it is the sensor itself as it had a much higher reading than the other 3 sensors when I had it tested at MSD last summer?Any help would be superb.
Many thanks.Lee.
Old Mar 31, 2010 | 06:01 PM
martysmartie's Avatar
martysmartie
The sensors are the same as are ones from Granada etc or any other ABS Sierra, what problems are you having?
Martin
Old Mar 31, 2010 | 06:21 PM
1374lee's Avatar
1374lee
Martin the abs light just stays on and has been like this since I purchased the car last May.Took it to MSD last summer for a set up and asked them to check it and it was found that the drivers front sensor was showing a much higher reading than the other 3.
CheeRS.Lee.
Old Mar 31, 2010 | 07:08 PM
nebby's Avatar
nebby
Hi, I've got one brand new Ł90 + p&p which will be about a fiver.
Can send you a pic of it to show you.
These were Ł92 when i bought them for my 3 door but they went over to the later sapphire.
Cheers Neb
Old Mar 31, 2010 | 07:14 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Evening chap I have a used one spare as I bought 2 off a lad on here (I only needed 1)
All I will be after is half what I paid for em both and postage
Pm me bud it will be cheep cheep like a budgie
Old Mar 31, 2010 | 07:15 PM
martysmartie
Ok so it is probably is a duff sensor. I wish you all the best in getting it out as they can be very tight, use plenty of penetrating oil first taking care not to get on disc. Have you tried cleaning?
Martin
Old Mar 31, 2010 | 07:22 PM
1374lee's Avatar
1374lee
Martin,the sensor has been taken out last weekend,wasn't a problem beleive it or not.
Thanks.Lee.
tankybaby66
Feb 6, 2016 02:24 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
