2wd cossie intercooler Vs big name cooler
Old Jan 11, 2005 | 05:52 PM
Robin's Avatar
Robin
Default 2wd cossie intercooler Vs big name cooler
how well does the cossie 2wd ic compair to 1 of the well known brands??
considering this as a cheaper option.
Old Jan 11, 2005 | 05:56 PM
rapidcossie's Avatar
rapidcossie
i have a 4x4 cossie cooler for sale. much better than 2wd.
yours for £50 plus p+p
Old Jan 11, 2005 | 08:53 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Think of the depth of the 2wd coller, or even better, as above, the 4x4 one.
You have the same width as say a GRS.......but 1/3 the height of the GRS. However, you have 3times the thickness . (All figures are an example!), so, potentially you have the same cooling capability as a bigger, thinner intercooler without blocking the rad!.
Old Jan 11, 2005 | 11:14 PM
GrimmeRS2K's Avatar
GrimmeRS2K
if u wanna cheap intercooler get a mr2 turbo intercooler, cut one of the pipes and weld it back on the other way, and your done, same size as a pace, fits easier, normally go for around 20-30 on ebay, one on there now, i run one on mine and its fine up to 17 psi
Old Jan 12, 2005 | 08:59 AM
JesseT's Avatar
JesseT
I have a GRS IC and even when using 30psi boost I can't virtually see any rise in ACTs at least in this time of the year. So I would say that the big big coolers are not really needed to be THAT big.
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
RsS2daz
Aug 14, 2015 05:26 AM
Blown Hell
Aug 5, 2015 07:22 AM
