St170 instrument cluster fault
hi, can anyone help with this problem,, over the the last 2 months or so the speedo, rev and fuel needles only worked every now and then. its now got to the point were they rarely work at all..the mileometer also dosent come on...all the lights work its just the needles that dont..ive removed the cluster and cleaned the circuit board but this hasnt made any difference... has anyone got any ideas on what could be wrong? or do i need a new instrument cluster..any help would be great
cheers
cheers
new cluster is needed iam afaid this is pretty common fault will cost £60 + vat for the part then it needs programming to as need the info off the old unit to ecu
dealer job too as need rds control unit to programme
