co adjusting help
Old Jan 11, 2005 | 04:53 PM
rsnitrouskev's Avatar
rsnitrouskev
Default co adjusting help
anyone no which way to turn it to richen it up is it anti clockwise or clockwise on a RST
Old Jan 11, 2005 | 05:01 PM
Moonie's Avatar
Moonie
Cloclwise to increase CO%, anti-clockwise to decrease CO%.
Make sure you have the pressure actuator disconnected when setting the CO.
Stu @ M Developments's Avatar
PassionFords Creator
clockwise.
Old Jan 11, 2005 | 05:06 PM
rsnitrouskev
is that the black plug on the side of the metering unit ?
Old Jan 11, 2005 | 05:12 PM
Moonie's Avatar
Moonie
Cant remember the colour of the plug to be honest, there are only two electrical connections on the metering unit (pressure actuator and air flow pot), its the one closest to the wing/fuel filter.
Old Jan 11, 2005 | 05:18 PM
rsnitrouskev
cool i know the one cheers buddy
Old Jan 11, 2005 | 05:19 PM
Wazzzer's Avatar
Wazzzer
cool, I need to do this as well, my CO2 was only 0.5 when it went for the MOT.
I've got one of those useful metering heads, as soon as you take the plate off to adjust it it cuts out...
Old Jan 11, 2005 | 05:21 PM
They all do that by design pal
The filler cap and dipstick should do the same thing to it if its working well
Old Jan 11, 2005 | 05:33 PM
Wazzzer's Avatar
Wazzzer
No I just meant all others that I've seen have got an extra piece on it that lets you adjust it without it trying to cut out...?
Old Jan 11, 2005 | 06:24 PM
Ahhh.. know what ya mean now
Thats a later revision
Old Jan 11, 2005 | 07:16 PM
Moonie's Avatar
Moonie
Any ideas on this one Stu...
1989 ERST, Idle speed started dropping - after a run it would idle ok for about 30seconds, then the idle speed would just drop off and sometimes stall (had to keep foot on accelerator to keep revs up).
Checked CO at work, CO was at 7% - i corrected CO and it seemed to have sorted the problem.
About a week later the same happned again, rechecked the CO and it was up to 7% again (engine warm).
Removed and cleaned the control lunger in the metering unit, it did not appear to be sticking, the air sensing flap is not binding either.
I reset the CO again but after a period of time it will self increase to around 7% and the idle will drop.
Any ideas/advice??
yatta
May 21, 2016 10:31 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
