garrett T35 info!!
Old Mar 28, 2010 | 01:45 AM
Thanasis's Avatar
Thanasis
Default garrett T35 info!!
hello,does anyone know what exhaust housing have this T35? thanks a lot
Old Mar 28, 2010 | 08:19 AM
wilky's Avatar
wilky
if it's a ford should have the .63 on it but you can change them
Old Mar 28, 2010 | 12:48 PM
LHD220Turbo's Avatar
LHD220Turbo
normally .55 i thought
have a look in the exhaust housing, do you see 5 stamped?
Old Mar 28, 2010 | 12:53 PM
paul16v's Avatar
paul16v
Monte 087
.55 housings are quite rare tbh, normally you will find them to have a .48 or a .63 that looks like a std ford unit off an escort cosworth so it should be a .63.
Old Mar 28, 2010 | 01:01 PM
Thanasis's Avatar
Thanasis
thanks for replies,yes it's from escort but it's not mine that turbo and i can't check it,thanks a lot all.
Old Mar 28, 2010 | 01:05 PM
LHD220Turbo
if its from an escort then it is likely to be .63
t34.63 were fitted as standard to big turbo escorts
Old Mar 28, 2010 | 01:10 PM
Thanasis's Avatar
Thanasis
ok thank you very much my friend
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Mc5506
Sep 29, 2015 09:06 AM
