Is cosworth suspension a straight fit onto a normal sierra?
Gary Krishna
As above.
I've just bought a sierra 2.0 ghia hatchback as my new runabout but the way it sits at the moment, it resembles an off roader!!!!
Just wondered if Koni suspension from a saph cossie would be a straight fit?
What he says, the rear shocks can be from either 2wd or 4wd, as simple to fit with a few washers either side of eye to fit 4wd or cut fown eye 1/4" off each side for 2wd)if 4wd eyes).
Just avoid the very early pigtail springs on front shocks, but if changing for strus at front as well all is good, pigtails were only very early mk1.
COSWORLD
Aug 14, 2015 07:40 AM
Aug 14, 2015 07:29 AM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
