capri 280 cosworth project (pictures)
THOUGHT YOU WOULD ALL LIKE TO SEE MY CAPRI 280 COSWORTH PROJECT,HAS BEEN SAT AROUND FOR THE LAST TWO YEAR DUE TO WORK COMMITMENTS,IN THAT TIME I NEARLY SOLD HER THEN CHANGED MY MIND AGAIN....SO IM BACK TO WORK ON HER THIS WEEKEND...
not yet mate,because its been sat so long i have whipped the engine out again to give it a good going over,should be back in next week then the matter of bolting everything back together....all the wiring is in but i am going to have to get my head around which ecu/chips to use etc...
cheers for that shaun..i have a set of greens and a set of light blues..just wondering which ones will be the best to use,i have a 3bar map sensor,t34 turbo with -31 actuator,bd10/bd14 cams.....what do you think ??? stick with the greens ??? cheers bernie
cheers for the comments,i cant wait till its finished but it aint half expensive doing it,keep running out of money having to save then doing a bit more...does anyone know how to identify ecu's ???? i have two in my spares box but dont know if they are L6 etc etc....cheers bernie
Look in ecu section, it tells the differances, nice car btw
Oct 9, 2015 07:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
