electric windows
help !!
the electric windows dont work in my escort.
theres power at the fuse box
theres power at the switches
both the motors work if i put power straight to them
checked the fuse
changed the relay
with out pulling the hole loom out im baffled.
anybody got any ideas. or a wiring diagram.
checked the fuse
changed the relay
Regulator is what moves window up and down, it is DRIVEN by motor, diden't reliase both windows were not working, is other side of switch when pressed getting power could be faulty switches, if yes then will be wiring from switch to motor a connector perhaps which serves both windows.
Martin
Martin
ive been out with a volt meter.
there is constant power at the switch black/yellow wire 12.5 volts with ignition on.
the wires that go to the motor blue and green
blue is up, green is down or the other way, cant remember
if i put a volt meter on either blue or green and press switch i only get 0.30 volts.
what does this mean.
As I say you need to check other side of switch with it closed to see what power you are getting there, if it mirrors your said 0.30V then will be dead switch. Could bridge the connection as a test as well.
Martin
Martin
Are the Escort switches individual then? Sierra rear window switches are the same as MK3 Fiestas the early ones at least. Escorts and Orions are the same owing to the Orion being a Escort saloon essentially.
Martin
Martin
chowfornow
14
Jan 5, 2019 09:01 PM
