Broken white S2 ERST 90 spec
Hello Scott you old chuffer!! Been a while mate! I've got a complete bottom end you can have. Requires a rebuild though. Yours if you wanna pick it up!
Mattseries2 - I've got a standard Escort dash with no holes cut into it. Its the dash that comes in the 'Escort Bonus' It's mint mate if I'm honest, from a 30k car. All you need to do is swap the soft vinyl part over form the left hand side and it should be a good 'Turbo' dash. I was going to keep it and get it flocked, but keeping mine standard now. Yours for a Ł10er if you collect.
Cheers, Sy.
Cheers, Sy.
Cheers, Sy.
Cheers, Sy.
Got a Black FRST but its currently running a XR2 bottom end so want to get a proper FRST one in there before I give it too much abuse
Will keep that one in mind though if I decide to rebuild one
Scott
Scott - The bores have been worn. There is quite a lip in them.
Milesy - I have a pair of rear strut covers. The cold start valve wiring I will have to look tommorow when I'm back at the unit and let you know.
Does it matter what colour the plug is? I've got loads of old loom bits hanging about....
I'll find a plug that fits the cold start valve with plenty of cable if thats ok?
Sy.
Sy.
Hello mate, what condition was the drivers door seal like? mine has the usual split at the bottom, like where they all break. If spot on, how much u want for yours posted to cm9 postcode, cheers
Essexmikesi - Drivers door seal as they all are mate - Fubared! Sorry.......
Milesy - Was just checking you weren't building a bufty machine/concourse etc etc. As long as it fits, it will work.
Conor.RST - PM on its way.
Sy.
Sy.
Milesy - Sorry bud, ain't got a plug at all that fits! I'll keep my eyes open.
I do have the pair of rear strut covers though if you still want them.
Sy.
Sy.
Milesy - Ł10.00 posted mate.
Smitsturbo - I take it you are after the rear hub with standard RST drum back plate? If yes, then I have it. Ł35.00 posted bud. (I might have to cut the tie bar off the hub as I can't undo the bugger for shit!)
i dont need the drum or shoes tho mind
Marc-Gti - Drivers door is de-locked. No rust I can see. Bootlid is good too - No rust. Has a 90 spec spoiler on it. Ł100 collected.
Rst230bhp - If its the screw with the spring on you are after, I have a spare. Ł5 posted.
Cheers, Sy
Cheers, Sy
Know what you mean mate! I got a couple like that.
F268 GYD - In scotland last I heard.....
G155 SCG - No idea!
And a couple of others I cant remember!
G155 SCG - No idea!
