rs turbo s2 escort
i am after the clip that hold the indicator in its like a ball joint end with a nut that screws into the wing thanks do these come on the indicators!!!!! as ford says no does any1 have indicators clear one with these on for sale thanks
Is this the ball ended bolt that the black headlight clips sits on? Undone with a 13mm spanner?
If it is, I think I have some. I'll have a look later when I'm down the unit.
Sy.
Sy.
Yep. I got one of the bolts. I've got a pair of clear indicators, but the thread on one of them is missing that this bolt goes into!! If you have another indicator, you can try replacing it.
You can have the lot £15 posted if you like.
Matt Baxter
Sep 16, 2015 08:30 PM
