mk2 escort - st170 engine advice
Old Mar 24, 2010 | 10:37 PM
mikehillmotorsport's Avatar
mikehillmotorsport
Default mk2 escort - st170 engine advice
got my engine in just need help with a few things -
what voltage goes into the cam solenoid - 5v or 12v?
what fanbelt shall i use - im not running an alternator just want to run the waterpump (obviously) so what fanbelt and idler/tensioner pulley?
do i need to slot my inlet manifold down if so how much and how - its a twin 40/45 alloy manifold.
also - i will be using a megajolt system i have bought of ebay - do i need a throttle position sensor or not? was told not if i have only got std. cams as i can download a base map?
thanks for any help.
Old Mar 25, 2010 | 09:16 AM
GAZBEAMCOZ's Avatar
GAZBEAMCOZ
got to www.turbosport.co.uk there is a load of people that have done this conversion and there will be plenty of help there ...cheers gaz
Old Mar 25, 2010 | 09:50 AM
XRT_si's Avatar
XRT_si
If you do a search on 'ST170' or similar, some of the above has been covered on previous threads.
Old Mar 25, 2010 | 09:32 PM
mikehillmotorsport
hi thanks for that - i have already read most of them and it cleared up a few probs -
i have just recived my megajolt this afternoon and it is just a load or wire and some connectors! - i have read thats its easiest to use the fiesta esc wiring and use this but how do you connect this to the megajolt ecu?
also do i have to slot the inlet manifold down?
thanks again.
Old Mar 25, 2010 | 09:43 PM
caprizetec170's Avatar
caprizetec170
ya will have to slot inlet manifold ports are about 5mm higher. as far as i remember solnoid is 12v i just removed pulley and fitted venieer pullys. ya could buy retro ford belt pulley i ust used ford one and mounted it in old power steering pump position. i used weber alfa ignition which needed tps
Old Mar 25, 2010 | 10:06 PM
mikehillmotorsport
thanks for that caprizetec1970 - i think ive sorted the fanbelt today - using a nissan sunny alternator belt. any other help with the megajolt would be greatley appreciated as i really havent got a clue!
Old Mar 27, 2010 | 03:56 PM
anton rs's Avatar
anton rs
hello mate try this website http://www.autosportlabs.com/megajol...self-p-39.html i have found it very intresting and full of usefull info of what to do and upgrades you can do with a megajolt.
Old Mar 27, 2010 | 03:57 PM
anton rs's Avatar
anton rs
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
kyle_st200
Ford Focus (All Models)
Aug 7, 2015 06:06 PM
