Introduction to escorts
Hi, Im looking for some info on mk2 escorts.....
First of all, Im assuming they run TCAs similar to a cossie, where the location is controlled by the anti roll bar?
Modifying this, you get camber adjustment with adjustable TCA's, supplied either rubber or polybushed?
Ive seen tension struts and compression struts, if one uses these, how does the arb interface?
Does anyone have any underbody shots of where they attach on the bodyshell?
I'm sure the Mk2 runs Macpherson struts which are located by TCA & AR. So you could fit uprated bushes & or adjustable arms.
If its the same as a MK3 Capri the AR is leading not trailing.
Dr. Ickxs
Sep 15, 2015 10:15 PM
