Will a 2wd Head be ok for 4wd setup
As above, I want to use the 2wd head I have just had rebuilt but am starting to find that 4wd bits arent bolting on ie, the thermostat housing.
Any help would be much appreciated.
Joe
Joe
would have thought so mate, the only things that are differnet really are the thermostat housing and the location of the temp sender, other than that other than the obvious differences like the maching to water ways and combustion chamber the rest should just be the same!!
how come the stat housing wont fit?! had a look at my 2wd head on the car and my spare 4wd head and they both have the same amount of holes drilled for housings...........
cant see it being a problem mate other than u having to change the hoses so their 2wd ones?!
Have u got a pic of the area the stat bolts onto, as tabs said u might just be able to get the 3rd hole tapped as its probably cast so it can have it done!!
Was gonna say looks like a 2wd pump not 4x4!!!
Also took a pic of my 4x4 head, urs doesnt seem to have the extra material machined flat where the 4x4 stat housing would mate too as tabs said must be an early head....
dojj
28
Sep 11, 2015 10:00 PM
