blocked breather?
Old Mar 22, 2010 | 07:36 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Default blocked breather?
hi ive got a 89 2wd saff just bought the car and been told the breather is blocked as the oil is getting pushed put the top would this make the car smoke quite badly white/grey smoke still starts first time ect just alot of smoke if not what woould you suggest it could be cheers
p.s also is it hard to unblock
Old Mar 22, 2010 | 07:55 PM
bad boy rs's Avatar
bad boy rs
prob would mate, the engine needs to breathe, pull the whole breather system pipes/tank off and give it a good blow through with an air line and see if it sorts the problem
Old Mar 22, 2010 | 08:02 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
cheers mate i cant stress how much smoke ther is tho fills the street lol just want it on the road
Old Mar 22, 2010 | 08:43 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Sure the turbo's not up the spout?
Old Mar 22, 2010 | 09:01 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
dont think so mate was told it was new and it looks new tbh how would i check anyways just out of curiousity im sure its not tho
Old Mar 22, 2010 | 09:09 PM
bad boy rs's Avatar
bad boy rs
does it stop when it warms up ? smoke on boost
Old Mar 22, 2010 | 09:11 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
ive only stared the car on the drive mate no tax or mot atm getting everything sorted first but it is alot worse when first started then calms down abit
Old Mar 22, 2010 | 09:15 PM
bad boy rs's Avatar
bad boy rs
could be the stem seals or turbo mate, my t3 went on my series 2 and it was a nitemare from cold poured smoke out
Old Mar 22, 2010 | 09:29 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
could also be piston ring blow by pressurising the engine and pushing the oil out the top
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
