RWD Zetec conversion
Hi,
First of all, I know the zetec shares its basic block architecture with the CVH, I assume this doesnt tail back to the crossflow?
Ive heard the water rail causes issues in rwd fitment, is this only a space issue for bulkhead clearance? Anyone got a decent pic of the OE arrangement?
Whats the best (cheapest and strongest) flywheel and clutch arrangement for a zetec onto a type 9? Ive read about rs turbo clutches and standard fwd mondeo ones and allsorts but not found a clear answer? (only looking to handle standard power in an 800kg car.
Can the original ford ecu be maintained in a transplant? Any links to wiring guides? Is the immobiliser easy to get around?
What sump patterns are available, Ive heard reference to front and rear bowl sumps? If chassis/crossmember issues are ignored, which will be best in cornering?
Im talking here about a silvertop 2.0 unit.
not in a saph.
i used a custom fly from ttv racing to take a 2wd cossie clutch and t5 gearbox, had a custom big wing sump made and used a water rail from retro ford.
click my sig for the build
Retro ford sell everything from exhaust manifolds to water rails and engine mounts to convert a zetec to rwd,loads of already done it,there is a dedicated zetec conversion section on turbosport.co.uk everthing you need to now is there
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
