Anti lag on my Fiesta rst
yes it possible
well for you to run a mild anti-lag setup anyway, to have the full on aggressive anti-lag you will need a mar-m-247 shaft in your turbo to take the heat, which of course adds a lot more expense
if im reading it right you want the sound/flames of it yes?
launch control with have the same effect (well roughly if it just when you stationary that your guna use it)
i know a slating going to be had when i suggest this but..............a flamer kit
ill be running ALS on my FRST when its back on the road, but im uprating most of my enigne and turbo stand up to the heat and well abuse it will be getting. Ill be running MTech ecu to be able to run the ALS and LC
247 shafts are crazy money now...I was after one about a year ago and as a part, most places wanted a grand! ended up getting a T34 off the bay for £800 with one fitted but dread to think what they cost now.
Remember it was claimed standard GT turbo's could handle the heat at their core? anyone tried it?
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
