Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Ecu help.
Old Mar 20, 2010 | 10:16 PM
Dan track ka's Avatar
Dan track ka
Default Ecu help.
Hi peeps. I have a 2.1 zvh conversion to put in my track ka. It has ofab ecu. I would like after market management but canny afford it right now.
My question is, can i run the lights, dials, starter, leccy windows etc through the KA original ecu and then put the RST OFAB ecu in with a live feed just to run the engine?
So basically, 2 ecu's, 1 for the lights etc and one for just the engine.
Thanks, Help really appreciated.
Old Mar 21, 2010 | 02:59 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
I have seen that before, it's a straight forward approch, try speaking to track developments. Let no how you get on with it, planing to build a zetec turbo ka in future. Im a ka nut lol
Old Mar 21, 2010 | 09:12 PM
Dan track ka
Thanks. So its just as easy as i said?
Old Mar 22, 2010 | 01:39 AM
NoRubNoDub's Avatar
NoRubNoDub
Bad example but I built a buggy a few years ago wit a mondeo 2 litre zetec, found no probs just running the engine off the stanard ecu, right up untill it got bashed on the side of the cage that is lol
Old Mar 22, 2010 | 01:42 AM
NoRubNoDub's Avatar
NoRubNoDub
Though your goin to have to run the starter off the zetec ecu, maybe a zetec s fez ecu would be a all in one solution
Old Mar 22, 2010 | 07:07 PM
Dan track ka
Cheers.
Ill need to use the rst ecu for the engine, starter shouldnt hassle me, ill be using cvh starter anyway so itll be in the wiring loom.
Old Mar 23, 2010 | 10:04 PM
Hobomassiv's Avatar
Hobomassiv
Originally Posted by Dan track ka
Cheers.
A lot of peaople have used 2 ECUs on Ka conversions.
My mate had a puma 1.7 ka running the puma ecu and the ka ecu and he also had an RST ka with both ECUs originally and then jsut the RST ecu after that.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
muzzman1
Sep 30, 2015 08:59 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
