275 miles on £42 of petrol
good
or bad
currently on stage3 803's and a good few 150+ outting over the last couple of weeks
personally I can't complain @ that figure
what u get out of your Cos?
or bad currently on stage3 803's and a good few 150+ outting over the last couple of weeks
Originally Posted by fireblade
MINE DOES 50 MILES TO £10.00 STG 1
I THOUGHT THAT WAS BAD
when I was stage 1 used to get about 300-350 miles to 60 litres
fooking hell, im lucky to get 200 miles to a tank tbh, i just done 25 quid driving from my house in central london to some place past blue water and back
my cossie is fooking drinking petrol for some reason !!!!!!
I'm soon to be on 403's with l8 loop lam/sensor and hope to see that sort of return also
Originally Posted by Alvyn
good
or bad
Hope mine will do nearer that when I get it set-up properly
On 803's never seen 100 miles on £20,even on a run
Get 80 miles on short journeys etc on £20,worked it out at the time to be 16 mpg
Driving the way I do, I don't usully get a lot,
My orion did 40 miles to a tenner or 200 to a full tank (£40) on Optimax
My saff does 50ish miles to a tenner or 120ish to £20 havn't filled it up to the top yet, don't know how that rates it's only stage 1.
(don't think its running right though, will be on Friday though going to MSD!!!
Stu, thats far better than my Mazda 6.
£45 to fill the tank, 360 miles at a steady 85mph! Who says modern cars are economical! Even my cossie manages 300 off a full tank at that speed!!
Thats said though checked out the curb weight and its over 1500Kg!!!!
PassionFords Creator
Am gettin around 310-320 miles to a tank in ma scooby if I'm not stupid with it. You can watch the guage drop when you're giving it stick!
275 miles out of £42 worth of optimax on a stg3 cossie sounds good to me.
How big is the tank in the cossie? I think the scooby is 56L The RST is only 47L or something like that as far as I remember?!?
275 miles out of £42 worth of optimax on a stg3 cossie sounds good to me. How big is the tank in the cossie? I think the scooby is 56L The RST is only 47L or something like that as far as I remember?!?
