could the co be lowerd with out
could the co be lowered with out altering the set up of the car i have a co machine and its runnig stage 3 ith 803s greens and its on a level 6 regutor is fine and not over udjusted but new sensor on the water system that controls the fuel so what now dont realy want to totch the screw in the ecu what do you think
PassionFords Creator
Originally Posted by abdr500
6 prsent wich is high it should be at 2 1/2 3 max is that right but will that mess up the set up that i had done about 5 moth ago at engine advantages
It cant have been 6 as that would be illegal of him as you couldnt have driven it home by law...lol.
Set it to whatever EA set it to.
_________________
_________________
since whens cowboy hills been botherd about legal
Keep movin', movin', movin',
Though they're disapprovin',
Keep them doggies movin' Rawhide!
Don't try to understand 'em,
Just rope and throw and grab 'em,
Soon we'll be living high and wide.
My heart's calculatin'
My true love will be waitin',
Be waiting at the end of my ride.
Move 'em on, head 'em up,
Head 'em up, move 'em out,
Move 'em on, head 'em out Rawhide!
Set 'em out, ride 'em in
Ride 'em in, let 'em out,
Cut 'em out, ride 'em in Rawhide.
so what you people are saying is i should bring the co down . thers only one way is that trough the screw in the ecu level 6 is that clock wise to lean and the other way is to richen is that right or is it the other way
yea i do alot of pre mot cheacks and always use the co machine and it all ways gets it right they roll in to a mot test center and roll out of one with no problem
no i havent iam not going to fiddel with the co screw only if i have to but this only started only once i changed my head gasket you seem to know alot on this topic .. my fuel presuer regulator is about 3 full turns from the bottom till it wount go no more so its not that high
what CO meter ya got btw
remember a halford 150 quid job machine is totally crap ( no offence and im sure ya already know this
ive tested one at work then used the sunn mot testing machine and to say it was a bit off is a understatment, my CO was 9%
tbh i think ya ned to see a tuner as for the sake of 70 quid ya can save alot more money, ya might even find its somink silly like oil in the zorst ect
abdr500,
so are all cossy runnig high co
My non lambda equipped software runs 2.5% max. My Lambda software runs 0.6% max.
3Bar fuel pressure with the pipe disconnected is wrong BTW. Its too low.
I recommend you simply call EA. Ask them what it should be set to foir their software, and use your analyser to set it if your confident its accurate and you have no other problems.
right update striped engine to find that my piston rings were fucked badly they had a very big ring gap and ther was even littel holes in the side of the piston rings and the oil control ring was like almost flush on the piston so gona build it and get it set up end off thanks gareth t and stu for your response
mrben
Aug 17, 2007 06:08 PM
