need some help with this
Old Mar 19, 2010 | 04:17 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
Default need some help with this
hi guys im thinking of upgrading my brakes i have standard hubs on the frount will cosworth 4 pots fit on them cheers
Old Mar 19, 2010 | 04:22 PM
rog's Avatar
rog
What car is it?
When you say "standard hubs", I'm a bit confused, as any brake kit doesn't involve changing the hubs.
Old Mar 19, 2010 | 04:24 PM
johnandhissaffy
Originally Posted by rog
What car is it?
sorry mate a sierra sapphire
Old Mar 19, 2010 | 05:09 PM
Wheel clearance allowing, they will fit, may need to tweak the caliper brackets over a touch using a few washer to get central.
If you tap the hub eye then 2wd 4 pots bolt straight on, with 283mm discs.
Old Mar 19, 2010 | 06:25 PM
iansoutham's Avatar
iansoutham
OCD Victim
John, have a chat with me @ the PF meet when I sort you out that loom. It would be easier to explain that to try and type it all out. Can probably source the bits you will need as well.
Old Mar 19, 2010 | 06:54 PM
johnandhissaffy
nice one will do that mate
