Where to buy these items?
Old Mar 18, 2010 | 07:58 PM
Rozvor's Avatar
Rozvor
Default Where to buy these items?
Hi
I'm looking for those items (ford spain don't have it) for my Sierra Cosworth 2WD
Numbers 17, 18 and 19
http://i43.tinypic.com/33ae1qb.jpg
Any online shop to buy it?
Old Mar 18, 2010 | 08:25 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Do they have to be new?
If they can be used, try Paul from NYRS off here (do a search), he probably will have used ones, best bet would be to call him though as he dont do PM's
Old Mar 21, 2010 | 07:44 PM
Rozvor's Avatar
Rozvor
Used is ok for me but NYRS hasn't an email on his web, only phone
Write/read english is ok for me but talking is a problem
Did you know any other site to buy?
Regards
Old Mar 21, 2010 | 07:48 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Try http://www.fordpartsuk.com/ for new parts.
Old Mar 22, 2010 | 05:56 PM
2001ode's Avatar
2001ode
Hi,
Number 19 is not for 2WD, it is for 4WD.
Number 17 and 18 don't exist anymore.
Do it yourself !!!!
Regards.
Claude
Old Mar 22, 2010 | 08:03 PM
Rozvor's Avatar
Rozvor
Thanks for the web but they haven't stock of the parts
Originally Posted by 2001ode
Hi,
Do it yourself !!!!
Regards.
Claude
Are you sure about the number 19? So, what part blocks the number 14?
I haven't the old parts and have no time to remove the gearbox of one of my other cars
Thanks to all
Old Mar 22, 2010 | 08:22 PM
Toe Knee's Avatar
Toe Knee
part 18 pushes into the bellhousing then part 17 stops the clutch fork (no14) from coming off!!!
As said no longer availile from ford and i very much doubt any of the breakers are likely to have them off of a gearbox as they pretty much always snap off!!!
What most people do mate is tap the hole so it has a thead then wind a bolt in so it holds it in place!!!
Old Mar 22, 2010 | 08:24 PM
AndyPen's Avatar
AndyPen
19 is just a pivot pin for the arm isn't it? I have seen short bolts used as a simple replacement.
kevin john bird
Sep 29, 2015 04:16 AM
pabloXR
Sep 21, 2015 12:42 PM
dojj
Sep 8, 2015 08:31 AM
