escort cosworth parts.
for sale escort cosworth st. rearbeam,diff,gearbox,rear springs, driveshafts, rear discs and calipers, all very low milage less than 46,000.
rear beam £35
rear diff £150
gearbox with reyland cradle bushes. £400.
rear springs £50
rear driveshafts. £60pr
rear discs and calipers. slightly rusty. in great working order.. £40pr
rear beam £35
rear diff £150
rear springs £50
for sale 4x4 strengthened and braced rear arms. the outer joints have been modded to take a rose joint (new one's included) will allow adjustment of toe. your beam cud be slotted to adjust camber. newly powder coated. £500 plus your standard rear arms..
terry durry racing ybp long studded block, 6 long studs. (just the block) has a score down 1 cylinder. £550 + postage.
2wd engine wiring loom, removed from my st escort cos. not the normal crispy wire's no issues with this, only taken out as going wasted spark. ect.
cosworth inlet plemun powder coated in black. £100 plus postage.
set of 4 escort cos pistons and rods, pistons showing some det. £100 + postage
just the block. it's on first oversize at the moment, have got pistons and rods. £100 ( pistons have some det.) been advised by tony @ turbosystems it would need a re-bore. or could be linered.
jessie_rs
11
Jun 3, 2019 04:57 PM
