Quick 1!
Old Mar 16, 2010 | 09:29 PM
matt24680's Avatar
matt24680
Default Quick 1!
hi there if i buy performance cams for my ford focus that say they are designed to work with original focus parts would there be any power increase if i buy paerformance campulleys or is it just vernier pulleys that improves performance?i think i might just use the original cam pulleys but just in case
thanks
Old Mar 17, 2010 | 10:23 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
if the performance cam pullys ar ajustable then there pretty much the same as veriers, cos the advantage with verniers are that you can ajust the avance and retard
Old Mar 17, 2010 | 02:45 PM
No cam pulley is going to give any increase, but those that allow adjustability so the cams can be swung either way on a dyno(valve clearance permitting) could give a little more, but if just cams personally I wouldn't bother, the cams will be produced/dialled to the best settings anyway.
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
