Ford Focus MK2 PAS High Pressure Line
Hi,
Do these come attached to the PAS pump or are they replaceable? Reason being mine is leaking at the pump inlet and the garage reckons I need a whole new Pump as the pipe is intergrated with this?
Surely they're trying it on, as I thought you could buy the high pressure line alone?
