escort 5th gear problem
Old Mar 16, 2010 | 01:16 PM
jay simpson's Avatar
jay simpson
Default escort 5th gear problem
when i try and change to 5th gear i find it awkward there seems to be a knack to it if i just change normaly it seems to not go into gear corectly as if its just like when you put a car into reverse and sometimes its not in enough and you get that grinding sound but then if i push it harder and over to the right a tiny bit it goes in and works fine is there any adjustments or is it the gear box but apart from that the box seems a1 i only got 68000 miles on the car and its a 1.4 petrol
Old Mar 16, 2010 | 07:12 PM
Sounds as though the gear linkage needs adjusting, very easy to do, haven't done one in ages, but basically it is put into a certain gear, I think it is 5th on a 5 speed and 2nd on a 4 speed, then a pin inserted through hole in the linkage, then tightened up on the clamp, a haynes manual would be a good bet, as my memory isn't!!
Old Mar 16, 2010 | 08:35 PM
jay simpson
Default thanks
are there any photos available for me ive never done this dont even know what it looks like cheers
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
RIB1122
Aug 3, 2015 09:20 AM
