escort cosworth over fueling on idle
Old Mar 15, 2010 | 07:03 PM
lukeyboy's Avatar
lukeyboy
Default escort cosworth over fueling on idle
ive recently brought an escort cossie which on idle you can really smell fuel with abit of blue smoke not alot but when you drive off it goes the car doesnt cough, splutter or miss fire, now the car can run 430bhp but at the min is running 370bhp the car has been sitting around alot and not been used much heres the car spec
t34 turbo
bd10 and bd14 cams
wrc inlet manfold with 8 blue injecters
2wd manifold
mahle pistons
lightened and balanced bottom end
group a wrc head gasket
group a oil pump
ahmed bayjoo chip
rs 500 front intercooler
l8 ecu
wrc loom
group a breather
group a fuel pump
swirl pot
oil pressure has got 5 bar on idle the car pulls fine but was wondering if a good tune up would sort the problem
cheers
Old Mar 15, 2010 | 11:42 PM
Danny @ Enhanced Performance's Avatar
t34 turbo
bd10 and bd14 cams
2wd manifold
mahle pistons
group a oil pump
ahmed bayjoo chip
l8 ecu
wrc loom
group a breather
group a fuel pump
swirl pot
cheers
i bet that car is K443 FYK ??????
pm me mate il tell you everything about that car..
cheers danny
Old Mar 16, 2010 | 06:50 PM
Tango Ford's Avatar
Tango Ford
Overfuelling causes black smoke..........blue smoke is oil in cylinder,valve seals ? turbo seal problems ?
Old Mar 17, 2010 | 04:49 PM
lukeyboy's Avatar
lukeyboy
but what if its only small amount of blue smoke its not an excesive amount like something serious
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
