droning noise from rear sounds like bearings - NOT
Old Mar 15, 2010 | 06:36 AM
Iktank's Avatar
Iktank
Default droning noise from rear sounds like bearings - NOT
another hint that may help others - I have done approx 127,000 miles and have obviuosly gone thro a lot of tyres and changed a few wheel bearings
On one occasion many miles ago the rear started droning again, and I had only changed the rrear wheel bearings 10,000 miles previous ( again stick to original parts had issues with pattern part bearings - only lasted 20,000 miles) on examining the back i noticed the tyres were stepping
This stepping is a common fault with cheaper tyres and block pattern design, I moved these tyres off the back and put them on the front no more droning noise on the back - on the front now!
So all I have done over the mileage I do is swap the tyres back to front every 60000 miles (the droning to the front soon dissapates as the tyres wear quicker on the front )
Old Mar 19, 2010 | 01:04 AM
B1G-J0E's Avatar
B1G-J0E
Slow and Low
I think i have this problem!
Will try.
Nice one
Old Mar 19, 2010 | 01:07 AM
alexno1dj's Avatar
alexno1dj
my steering wheel seems to have a slight judder at 70-75mph since putting my new wheels on. does this mean they need balancing or would swapping front to rear help?
Old Mar 19, 2010 | 01:23 AM
B1G-J0E's Avatar
B1G-J0E
Slow and Low
Balance the wheels and tracking
Old Mar 19, 2010 | 01:36 AM
botters's Avatar
botters
competant bodger
fook me i wish my tyres lasted 60,000 miles im lucky to get 5,000!
Old Mar 19, 2010 | 06:23 AM
Iktank's Avatar
Iktank
whoops meant 6000 miles, would be good if they lasted that long DOH
Old Mar 20, 2010 | 06:32 PM
airzfocus's Avatar
airzfocus
i would put money on it being drivers side driveshaft, is the car lowered??? i had the same noise thought it was rear bearing had them changed the same, done the fronts... same. decided to put it on axle stands and put the car into 1st and let the wheels just go round, and could hear it clearly coming from driveshaft, wear out quickly if car is lowered.
rex647
Mar 6, 2022 06:20 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
turbowag
Sep 3, 2015 08:07 AM
