Thermostat - pattern part problems
Old Mar 15, 2010 | 06:26 AM
Iktank's Avatar
Iktank
Default Thermostat - pattern part problems
over the last few years have replaced the bakerlite thermostat housing twice due to cracks leaking. Rubbish part
I replaced the thermostat the last with pattern part as Ford did not have an orig in stock.
No probs for a few moths but then had leak again it transpired it was the rubber ring to the the thermostat this time
The pattern part ring is not as thick as the original, over time it also lost a bit of its elasticity so water started leaking past it
Moral of this use original part - thermostat and ring only costs approx £14.00
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
