Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
toolbox organisers?
Old Mar 14, 2010 | 01:12 PM
fraser9764's Avatar
fraser9764
Default toolbox organisers?
how do you keep yours tidy? i've seen spanner rails on ebay, and ive got a few sets of socket rails but they are pretty shit really,
i was thinking about cutting a piece of plywood to screw the socket rails down to. anyone found any better products or ideas?
Old Mar 14, 2010 | 01:16 PM
G420 DEL's Avatar
G420 DEL
i just riveted the rails to the draw bottoms worked a treat
Old Mar 14, 2010 | 02:07 PM
fraser9764's Avatar
fraser9764
dont really want to drill into my new box though, i think i'll try some plywood
spanners are my main problem though, especially if the box is in the back of the van.
Old Mar 14, 2010 | 02:21 PM
Thrush's Avatar
Thrush
Irritating c........
I use these;
and these;
for the spanners in my tool box. First set are in one of the smaller draws for random spanners, second type is in one of the bigger draws for my ratchet spanners. It's actually a Halfords spanner rack, and it actually locks the spanners in it as opposed to them just sitting in it. So you have to twist them slightly to come out. Excellent as they don't all fly around when you're throwing the van over speedbumps
As for sockets, I just use the normal style socket rails I bought from Machine Mart YEARS ago;
Cut the rail down to desired length, slide on as many socket holders as you need and done. I have a socket rail for 3/8" drives, another for 1/4" drives, another for Torx sockets and another for reverse Torx. Not bothered to bolt em down or rivit them; just leave them in the drawer. If you have rubber matting and/or anti slide draw liners, they don't go anywhere. Also means it's easy to grab the entire rail if you need more than one socket on a job.....
Old Mar 14, 2010 | 05:21 PM
fraser9764's Avatar
fraser9764
they look pretty good, ill have a look on the halfords site in a few mins. any ideas for screwdrivers?
cheers.
Old Mar 14, 2010 | 09:26 PM
Thrush's Avatar
Thrush
Depends on what type of screwdrivers you use. I mainly use a Snap On ratchet screwdriver so it has interchangeable bits. I also have a Facom screwdriver which is just handle with interchangeable "blades", and these I just have in a slotted block of foam. I do have a few "regular" screwdrivers, and these just sit in one of the smaller draws, or in the lift out tote tray in the top...
My box is this one;
And top left to right to bottom is;
Row 1 left to right : Pliers and cutters / misc spanners / mole grips, assorted wrenches
Row 2 left to right : Screwdrivers / hammers and punches / rivit gun and rivits
Row 3 : Ratchet spanners, sockets and ratchets + assorted ratchet accessories
Row 4 : Cutting tools (blades, knives, etc)
Bottom deep drawer : everything else, but mainly stuff I don't use all of the time
Top Tote tray : most used tools : screwdriver + bits, 10, 12 + 13mm spanners, couple of knives, pick and hook tools, pigs foots, trim and pry tools, stubby screwdrivers, fixed flat and philips screwdrivers, and other varying bits n bobs I use on a daily basis
I'll try to remember to get some pics sometime. I'm not working at the moment so it's tucked in the shed under a load of other shit!
Old Mar 14, 2010 | 11:01 PM
nuttynil's Avatar
nuttynil
RS nutta
try http://cgi.ebay.co.uk/SPANER-RACK-TO...#ht_500wt_1182
Old Mar 14, 2010 | 11:04 PM
nuttynil's Avatar
nuttynil
RS nutta
try these i am about to order these
http://cgi.ebay.co.uk/2-Pairs-of-Cro...#ht_1319wt_939
Old Mar 14, 2010 | 11:17 PM
jacko's Avatar
jacko
thse are good the company makes them to suit your tools to
http://cgi.ebay.co.uk/bluepoint-snap...04184002r14721
Old Mar 15, 2010 | 08:04 AM
Brian's Avatar
Brian
Thats what i use for my spanners
Brian
Old Mar 15, 2010 | 08:19 AM
B16JUS's Avatar
B16JUS
I use the snap on a288a about Ł40
and the snap on spanner racks abnout Ł7
Old Mar 15, 2010 | 04:19 PM
James_RScos's Avatar
James_RScos
The Socket trays are great, also means you can take out all your sockets with you if you like!!
Old Mar 15, 2010 | 04:20 PM
James_RScos
Old Mar 20, 2010 | 07:06 PM
fraser9764's Avatar
fraser9764
getting there now, spanner rails turned up today, just waiting for some screwdriver racks and socket trays
from this
to this
Old Mar 20, 2010 | 10:43 PM
nuttynil's Avatar
nuttynil
RS nutta
yeah they are good must get some of them
Old Mar 31, 2010 | 07:29 PM
white2lsr's Avatar
white2lsr
I use these for my sockets (SEALEY). Much better than a socket try IMO
Old Apr 4, 2010 | 02:54 PM
Thrush's Avatar
Thrush
Little re-jig of the layout, and a week on the van and it's not nearly as organized as normal Need a new pair of spanner rails as I pulled out the originals to swap stuff around and now can't find them - think I binned them by mistake
and the rest in case anyone's interested;
http://img.photobucket.com/albums/0703/Thrush/box.jpg
http://img.photobucket.com/albums/07...ttomdrawer.jpg
http://img.photobucket.com/albums/07...sh/cutting.jpg
http://img.photobucket.com/albums/07...ush/middle.jpg
Old Apr 4, 2010 | 07:42 PM
Dave2302's Avatar
Dave2302
Tranny Man
I didnt want to drill my snap on cabs either, I got a sheet of 3mm allyminiyum and drilled and riveted the socket rails to it. It lifts out of the top of the box then, not that I ever do unless cleaning the box lol.
Use the plastic snap on spanner rails like at top of thread, with double sided tape holding 'em in drawer bottoms.
Screwdrivers socket extensions, plier sets etc I keep 'em in the drawers in the moulded snap on trays that they come with.
Don't transport rollcab or top box though it's too bloody big for that. It was a nightmare when I moved from Kent to Scotland, but as I had bought a lorry to move all our stuff I fitted a tail lift to it, twas easier than stripping the box drawer by drawer. I was shitting myself when it was going up on the tail lift tho !!
Cheers Dave
Old Apr 5, 2010 | 08:26 PM
andyd9577's Avatar
andyd9577
I try and keep all the original packaging for screwdrivers, prybars etc,
i use some spanner racks and snap on socket rails
Worse thing about the box i have is the yellow draw liners, which im in the process of changing to black,,,
File Type: jpg
Old Apr 6, 2010 | 11:31 AM
Dave2302's Avatar
Dave2302
Tranny Man
Nice and neat, good to see you're like me and chose a colour other than Red for the box lol.
Don't suppose yr near me are you, coz I've got a huge roll of black uncut drawer liner.
Cheers Dave
Old Apr 6, 2010 | 07:38 PM
Thrush's Avatar
Thrush
I really wanted a blue box! I think they look great in red don't get me wrong, but they look really cool in blue!!!
I'd love to have my box in blue!
Old Apr 6, 2010 | 09:32 PM
andyd9577's Avatar
andyd9577
Cheers Dave
cheers for the offer Dave,, just got a big box full off snap on man,,,,
just getting around to replacing them all,,,
Andy
Old Apr 16, 2010 | 10:57 PM
Iain Mac's Avatar
Iain Mac
Me too. My eyeight isn't as good as it used to be so I like being able to see at a glance what size the sockets are on each peg. I've got 1/4, 3/8 and 1/2 inch versions and it's just a pity they don't match the drawer sizes better.
I got them from our local engineering supplies place - they had to order them in but they were about half the price they were on ebay.
Old May 8, 2010 | 02:30 PM
Brookesy's Avatar
Brookesy
I use those sharks teeth for holding all my spanners & for the sockets I use plastic trays with numbered posts.
Just need to sort some storage out for the various other sockets that won't fit on the posts.
Old May 8, 2010 | 03:18 PM
.Ross.'s Avatar
.Ross.
I just chuck it in the box and get the fuck out mate ..
Jun 26, 2017 06:18 PM
phs84
Sep 15, 2015 05:30 PM
Shows & Track Days
Aug 17, 2015 08:56 AM
Thrush
33
Oct 5, 2004 12:55 PM
