r reg escort gearbox
Old Mar 13, 2010 | 10:17 PM
jay simpson's Avatar
jay simpson
Default r reg escort gearbox
hi all ive a problem geting 5th gear it just dont go in and when ive selected it and left out the clutch i just get a grinding noise but then somtimes it works any ideas do i need to change the box its a 1998 1.4 will any escort box fit please helppppp
Old Mar 13, 2010 | 10:27 PM
rs-tuner's Avatar
rs-tuner
Sounds like something is bent or broke cheepest option will be to put a new box in
Old Mar 13, 2010 | 10:29 PM
Rab's Avatar
Rab
Fucking superstar........
Sounds fucked mate. Your best best is to get down the breakers and get hold of a 2nd hand box. It's not a hard job to swap them, even a garage wouldn't charge you that much labour. Grinding + Gearboxes is usually very bad....
jay simpson
Default yes
will a1.8 diesel escort gearbox fit the 1.4 petrol engine
Old Mar 13, 2010 | 10:30 PM
Rab's Avatar
Rab
Yes.
Old Mar 13, 2010 | 10:34 PM
jay simpson
Default cool
would i just leave the clutch on my engine and the diesel box will fit on and then would i use my original driveshaft my car is a 1.4 cvh 1998 are you saying that all the escort boxes fit each other
Old Mar 13, 2010 | 10:46 PM
Rab's Avatar
Rab
Yes. All the boxes will fit. The diesel being stronger is a bit of a myth I think. And if it's a 1400, do you really need an uprated box?
Old Mar 13, 2010 | 10:55 PM
forevaford's Avatar
forevaford
i dont think the diesel box will fit
Old Mar 13, 2010 | 10:58 PM
Rab's Avatar
Rab
why not? It's the same bellhousing stud pattern, the input shafts are the same, the drive shafts are the same, the thing obviously fits into the bay as it come on the diesel escort. the ratios are different, and the myth is the diesel boxes are stronger.
Old Mar 14, 2010 | 04:01 AM
CRAIG HAYTER's Avatar
CRAIG HAYTER
a diesel gearbox will fit and its more stronger
Vincereese
Jun 1, 2023 09:14 AM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
