job lot of escort mk6 and mondy mk2 parts, garrett turbo, white clocks, td de-cat
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
right im having a big clear out as wifey has told me i cant spend any more money on the van:blush until this lot has gone. plus im skint :cry
im also re-adverstising anything previous in this thread so im sorry if theres duplications.
please note although all items were working before removal (unless stated) im selling them sold as seen your more than welcome to come and have a look and see for yourself.
garrett turbo, exhasut manifold, inlet manifold, egr and actuator. removed from an escort 1.8 td but can fit fiesta or mondeo td's
was working fine when removed.
info
P/N - 96ff6k662 ab
Gal/N - 452084 - 7
S/N aeo5790a
escort mk6 front electric window loom, includes door locks, one touch relay, window motors and frames and door looms. one plug is missing on the door loom but the pins are there to plug in.
mondeo mk2 1.8td intercooler, inlet manifold and intercooler hose. the hose is in great condtion and are hard to find like this without buying new.
mondeo mk2 1.8td de-cat pipe. i took the standard cat converter, cut it open, cut the elemement out of it and re-welded. (see my guide)
mondeo mk2 1.8td endura-de rocker cover, with bolts and oil cap.
escort gti abs module was working fine before removal.
escort gti manual door mirrors, in red but faded. glass is ok. comes with inside door covers
escort gti fornt shock absorbers, ok condition but one spring is cracked.
escort gti white dials, reading 91k miles (but easy to swap your speedo) may have 1 or 2 bulbs missing of back but were working fine before removal. been stored face up.
escort front and rear standard speakers. plugged in and tested and make a noise!!! there not the best quality as we know but good for replacing aftermarket speakers to sell.
escort centre console/column. in good condition
escort dash wiring loom from a gti. air-con loom with footwell light sockets. comes with air-bag controller.
escort tailgate/boot gas-struts
escort and mondeo interior lights
escort front fog lights
escort rear seat runner covers, good to replace your damaged ones. 3 of
escort drivers side seat runner cover, good to replace your damaged one
escort steering column surround, top and bottom.
escort rear lights, some surface scratches but were working fine, has rear bulb holder panels
escort gti fuse box, comes without fuses or relays. part number 97ag14a073bb
escort van speedo dials, may have 1 or 2 bulbs missing form the rear. stored facing upward
ford 1.8 diesel or td filter housing and pump. also commonly used on generators and external tanks fuel tanks.
ford 1.8 diesel of td injector pipes
mondeo 1.8td air filter box, maf sensor and inlet (filter box to turbo pipe)
mondeo mk2 grill in silver. surface scratches
various fuel, oil and water pipes form escorts and mondeos.
mondeo mk2 headlights. some surface scratches and has had beam benders stuck on and removed. still a bit of sticky there but good for repacements
escort drivers side headlight, good for glass only
mondoe mk2 rear lights some surface scratches.
ford 1.8td lucas injector pump. spare or repair.
escort dash with dial surround some minor marks and scratches. good for being sprayed or flocking.
ford mondeo steel wheels and tyres. tyres look ok and have some tread on them. one rim is dented slightly. good as spares or for putting on your motor whilst having yours re-furbed or havign your motor sprayed.
2x escort power steering racks.
P.M for any additional info
Ł250 ono
info
P/N - 96ff6k662 ab
Gal/N - 452084 - 7
S/N aeo5790a
Ł250 ono
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
