yb oil pressure?
Old Mar 13, 2010 | 07:37 PM
cossiedrift's Avatar
cossiedrift
Default yb oil pressure?
Hi all what oil pressure should i have at idle and say 3.5k? I have just put a new pump in my escos but pressure seems low to me.
Old Mar 13, 2010 | 07:43 PM
turnover's Avatar
turnover
30 plus on idle and 65 plus at 3500
Old Mar 13, 2010 | 07:44 PM
ickey818's Avatar
ickey818
On my Saph I get between 25-30psi pressure at idle with warm engine and between 60-70 psi when driving. What pressure are you getting?
Old Mar 13, 2010 | 07:48 PM
smartrs's Avatar
smartrs
where did you get your pump from ?
Old Mar 13, 2010 | 07:52 PM
cossiedrift
Its a genuine 2wd pump from matt lewis because i'm running 2wd. The gauge in the car is reading just above the red on tickover warm.I also have a pikey mechanical gauge showing around 1 bar when warm on idle. raise the revs and the pressure rises fine just seems low on tickover. Think i'l buy a decent gauge and see whats happening.
Old Mar 13, 2010 | 08:04 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
does your oil light ever flash when going round corners?
A bar is low tbo, im sure the oil light comes on just below it, saying that its been a while since i had mine
Old Mar 13, 2010 | 08:10 PM
cossiedrift
not driven it yet mate
Old Mar 13, 2010 | 08:20 PM
tomoyb's Avatar
tomoyb
i think its either 6 or 8 psi the light comes on,then its too late
Old Mar 13, 2010 | 08:38 PM
COLEYST200's Avatar
COLEYST200
never trust the light as my crank went over a year agow and we had 10/11psi and no light and the crank was banging it head off
iv got a standerd pump in my yb out of a pinto and iv 58psi cold tick over 40 hot and 58/60psi hot at 3,500rpm
Old Mar 13, 2010 | 08:40 PM
john_p_b's Avatar
john_p_b
what oil you got in? Mine was shocking on running in oil but dropped some proper oil in and it's perfect. Around 30psi idle, 75/80psi above 3k
Old Mar 13, 2010 | 10:10 PM
kcosneil's Avatar
kcosneil
i snapped my crank in two and drove it six miles home. went ok. but a bit niosey
Old Mar 28, 2010 | 08:13 PM
cossiedrift
how shocking mate? im going to put mobil 1 in on tuesday see if that makes a difference
Old Mar 28, 2010 | 08:27 PM
john_p_b's Avatar
john_p_b
was pretty much half of the figures i'm now getting with proper oil in it.
Old Mar 28, 2010 | 08:34 PM
BRAMMER's Avatar
BRAMMER
Mine is 50-55psi at idle - warm idle 35psi yet to note driving
Old Mar 28, 2010 | 08:41 PM
righthooker's Avatar
righthooker
ihad a guage in bar ,fresh build was 4bar idle ,and 7 at speed,dropped to 2bar after a hot lap at the nurburg ring at idle ,but allways good at speed
Old Mar 29, 2010 | 02:12 PM
I have 100psi hot, before even starting the engine!!, must put the sender on, keep forgetting.
Old Mar 29, 2010 | 02:21 PM
Toe Knee's Avatar
Toe Knee
mine with mobil1 on a racetech gauge is showing 25-30psi when warm, althou ive got a 4x4 pump in mine
Old Mar 29, 2010 | 05:43 PM
cossiegreg1's Avatar
cossiegreg1
25 psi hot idle
80 psi cold
Old Mar 31, 2010 | 05:20 PM
cossiedrift
70 PSI cold but ONLY 8PSI hot whats your thoughts?
Old Mar 31, 2010 | 06:23 PM
martysmartie's Avatar
martysmartie
Get a decent gauge to start with then go from there, also what oil are you using?
Martin
Old Mar 31, 2010 | 06:39 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Dan
I sent a couple of gaskets for you, failing that give us a call
Matt
Old Mar 31, 2010 | 07:24 PM
105epwr's Avatar
105epwr
the manual on the yb stats 2.4bar@2000rpm
Old Mar 31, 2010 | 08:37 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
when you had sump off, did you check oil squirts if it has them?
Old Mar 31, 2010 | 08:45 PM
cossiedrift
Originally Posted by Matt Lewis
Dan
Matt
Ok mate cool when did you send them? not recieved them just yet.
Old Apr 1, 2010 | 08:53 PM
cossiegreg1
sounds about right
SMILER258
Sep 28, 2015 09:04 AM
