Bloody Cosworth
Hi Guys, any davice would be a big help.
the car is currently stage 3, has 803, map and chip, along with bigger acuator and intercooler.
ok the car has a spark has fuel to much and the timiong is all correct. ive done compression test and its got good compression across all four. now the problem is its putting far to much fuel in the cylinder to the point ive had to change oil due to full of fuel.
if i unplug injectors and turn the car over to clear out any existing fuel thsats fine, but when i plug injectors bk in it will start for 5 second ish then cut out and not run again.
Any help would be great, as im abouts to pull my hair out
Also the bottom end has recently been rebuilt wll full documentation of work carried out.
Sorry if i have gone round the houses with my explanation.
Thanks Steve
Thanks Steve
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Adam Graham
Sep 6, 2015 06:04 AM
