new clutch
hey i need to replace my clutch and im wondering what i actually need to get to do it all properly
have been searching the net and all i keep getting is rubbish
so if anyone could help on what parts i need to get to replace the whole thing that would be great
thanks
thanks
what car year engine size?
in general you'll need a friction plate, pressure plate and release bearing, if it's a hydrolic clutch you'll need a clutch slave cylinder too, may aswell replace the latter just for piece of mind, cos if it's inside the box like on mondeo's you'll be doing all the hard work twice.
i'm pretty sure it's a cable operated clutch so just everything in that list above apart from the clutch slave cylinder, a search on ebay will pull up all the parts needed, a clutch kit should have it all in one box, just check it also has the release bearing included.
thats all you need tbh, not a technical job really just a pain in the arse to get too.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
