Info Required ****fuel tank*****
Hi guys
just started to remove my fuel tank and the bloody bolt on the tank strap seems to have broken the captive nut any easy way of getting bolt out, on my back on the bloody drive.
Any info would be great
i had exactly the same problem when i removed mine.
they only way i could do it was to grind the head of the nut off, and then wiggle the rest of the bolt and the captive nut out of the hole.
i also did mine on my back on the drive
hope that helps
Adam
hope that helps
Adam
This is exactly how i done mine as well
wowk
Mar 30, 2021 07:49 PM
