8.72secs 0-100mph on blown headgasket!!!!!!
Old Jan 9, 2005 | 08:44 PM
rs4steve's Avatar
rs4steve
Default 8.72secs 0-100mph on blown headgasket!!!!!!
had the main man round to day andy fisher from brooklyn ford (touring car mechanic from 1988)
another one gone from performance ford daddy bash took the head gasket out between 2 and 3 cylinders compression down blowing boost into water system leads me to beleive are the wrc headgaskets not built for the job? anyone else had problems running 34 psi of boost?
Old Jan 9, 2005 | 09:41 PM
martinrs500labatts's Avatar
martinrs500labatts
no,
is your block though studded ect,
my old car was 34 psi and never had any problems,
Old Jan 9, 2005 | 09:44 PM
essexrsturbo's Avatar
essexrsturbo
lovely looking car mate!
Old Jan 9, 2005 | 09:45 PM
rs4steve's Avatar
rs4steve
hi martin yeah long studded will be taking to bits in week to see whats happened not very happy car only done 1500miles since harvey gibbs fitted a wrc gasket for me and set it up on dyno not a happy man
Old Jan 9, 2005 | 09:47 PM
rs4steve's Avatar
rs4steve
thanks shame its not going very far in next couple of months
Old Jan 9, 2005 | 09:54 PM
martinrs500labatts
you might have been unlucky,
bob murrey from scs built my old engine,
all you can do is as you say take it apart and try and find the problem,
Old Jan 9, 2005 | 10:59 PM
puddy's Avatar
puddy
Who fitted the long studs?
I have heard o f them not going down far enough if the block is'nt machined deep
enough for them,and then holds the head proud of the block.
I measured the long stud thread ,and depth in to the block when I built mine,
this was a good tip from scotty
puddy
Old Jan 9, 2005 | 11:03 PM
Stu @ M Developments's Avatar
PassionFords Creator
puddy
That issue rears its head when the o'ring waist area is left slightly proud of the block decking. Your quite right and ive seen it myself on 2 occasions....
Old Jan 9, 2005 | 11:12 PM
puddy's Avatar
puddy
puddy
not just a pretty face
puddy
JoeyBoyden
20
Aug 22, 2015 03:23 PM
