leaky sapph
Old Jan 9, 2005 | 08:27 PM
steviep's Avatar
steviep
Default leaky sapph
Got a puddle appeared in my drivers side foot well, heater matrix is fine, defo no leak from the sunroof, windows etc, had all the carpets up and checked for holes in the floor so it's not that either.
Thing is, there's no sign of where it's coming from cos there's just a puddle in the footwell, no trace of water running down from anywhere, and the carpet is bone dry everywhere else.
WHERE'S IT COMING FROM?!!!!!
Old Jan 9, 2005 | 10:38 PM
velocity's Avatar
velocity
had this before and it may be you problem aswell and took me ages to find it if you look down in between the front of the fuse box and the black metal firewall in front of it.in the corner you will see a small rubber flap about a inch square or less which acts as kind of air pressure relief flap, make sure its not stuck half cought in its opening,if it is it can let water drain down onto the loom rubber bung below it going through the bulkhead,and if the rubber bung has extra wires or boost gauge hoses going through it,it can cause water to leak in and you wont see it because its behind the inside bulkhead matting,you could put some extra sealant around the bung and try it out,but you will need to pull the inside matting away to be sure its comming from there or cured
Karl 3dr
102
Oct 14, 2016 08:17 PM
DavidK
Sep 27, 2015 02:55 PM
Cos500
14
Sep 2, 2015 05:48 PM
pegaz
11
Aug 9, 2015 06:40 PM
CosRush
Jan 2, 2004 10:53 AM
