Plug identification
Old Mar 10, 2010 | 05:24 PM
cossie330's Avatar
cossie330
Default Plug identification
Hi does anyone know where this goes(the red one) on a 4x4 cossie
Cheers Jason
Old Mar 10, 2010 | 05:39 PM
danzul's Avatar
danzul
just a guess as i no next to nothing about these but could it be the ignition coil?.... pretty sure thats what im thinking of
Old Mar 10, 2010 | 07:09 PM
cossie330's Avatar
cossie330
Hi no not the ignition coil as thats all connected, if only the label i had on it didnt come off
Old Mar 10, 2010 | 07:11 PM
TOMMY_RS's Avatar
TOMMY_RS
SHITE!
i would wait til tabetha comes on and see's this post lol.
is there any plugs etc unlplued it might go to? that you can see?
Old Mar 10, 2010 | 07:21 PM
Not seen one like that, not std as far as I can recall, is it a wire as it looks very thick gauge for that sort of connector, look in the end, maybe it is a vac connection, soon see if there's a terminal in there, if not follow other end see where it goes, maybe for something that is no longer on the car ?
Old Mar 10, 2010 | 08:35 PM
BigFaceDave's Avatar
BigFaceDave
I have one of those too! Seems to be attached to the distributor cap
Old Mar 10, 2010 | 09:16 PM
martysmartie's Avatar
martysmartie
As said it looks like a vaccum hose with an electrical like connector only electrical connector on, not one I know of as standard if electrical, dizzy should be phase sensor and the ignition leads on the cap!
Martin
Old Mar 11, 2010 | 01:47 PM
Welcome BigFaceDave,
I've never seen a cap that would take a fitting like that, best way is to follow it to see where it hides!!
Old Mar 11, 2010 | 01:50 PM
cossiejsy's Avatar
cossiejsy
You sure its not off the coil
Old Mar 11, 2010 | 05:31 PM
cossie330's Avatar
cossie330
found it to be for the starter solinoid, cheers
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
