Malfunction indicator light not working.
Old Mar 9, 2010 | 07:44 PM
TommyT913's Avatar
TommyT913
Default Malfunction indicator light not working.
The MIL in my 3 door is currently not working. It doesn't light at all, not even when I first start the car. I am unable to pull codes as well. I switched the bulb to no avail. It should be noted that the ECU has been converted to a Level 8 with a Stage 3 MSD chip. Is this normal? If not, what should I look at to correct the problem.
Thanks in advance for the responses.
Tommy
Old Mar 10, 2010 | 04:28 PM
TommyT913's Avatar
TommyT913
Noone?
Old Mar 10, 2010 | 06:02 PM
oldford's Avatar
oldford
Try it with a Level 1 (but do not start the car), just to check the connections.
Old Mar 10, 2010 | 09:09 PM
TommyT913's Avatar
TommyT913
I reconnected the Level 1 computer that I replaced to check and I still wasn't able to get the light to work. When I connect the fault code reader I get nothing..... Where should I start to try and track this thing down. It should be noted that the car is running fine. It's just really annoying that the light is no longer working.
Tommy
Sep 28, 2015 10:05 AM
Cossikev
Sep 13, 2015 02:00 PM
The Enigma
Sep 12, 2015 10:12 PM
