Cosworth suspension setting units !!
Fitted adjustable rear beam over winter and will soon be taking the car for wheel alignment check and adjust.
But i have a question on the TOE setting. These seem to be quoted for the cossies in mm. What is this in Degrees Minutes (o ') ??
thanks
thanks
http://wiki.seloc.org/a/Geo_Setups
Converting from mm to degrees:
1. Multiply rim diameter in inches by 25.4 to get rim diameter in mm.
2. Multiply the result by PI to get the circumference.
3. Divide the result by 360 to get mm per degree.
4. Divide the toe mm by the mm/degree result to get toe in decimal degrees
What do you think of your beam so far Dave?
Will
225/35 17 road
225/45 16 track
Mike
How you doin ?
Thanks for the info/link
Beam looks nice !!!! cars not back on its wheel yet though. Maybe it will be by the end of the week.
225/35 17 road
225/45 16 track
Mike
How you doin ?
Aug 14, 2015 07:29 AM
