coolant fans are on? vw diesel
Old Mar 6, 2010 | 07:12 AM
cosmatt's Avatar
cosmatt
Default coolant fans are on? vw diesel
Hi all,anyone clued up on diesel vw transporter vans? When ignition is turned on now, all the coolant fans are coming on. Are they controlled via the ecu using a coolant sensor? Is this how modern diesels work? Thanks in advance..
Old Mar 6, 2010 | 08:00 AM
cossiegreg1's Avatar
cossiegreg1
if you look the fan will be belt driven, it stay,s on all the time.
my passat and bora are like this..... so i assume the transporter will be same
Old Mar 6, 2010 | 03:46 PM
muttsnutts89's Avatar
muttsnutts89
is it t4 or t5, has it got air con ?.
Old Mar 6, 2010 | 03:49 PM
RichieST's Avatar
RichieST
Says fans are coming on when ignition is turned on so probably not belt driven.
As above, does it have air con? I know on the fords the a/c comes on automatically when the fan position is set to windscreen, thus turning on the fans. Maybe vw are the same?
Old Mar 6, 2010 | 03:52 PM
James @ M Developments.'s Avatar
sometimes this also happens in limp home
Old Mar 6, 2010 | 04:50 PM
cosmatt's Avatar
cosmatt
Sorry,its a t5 2.5 130. No belts at all on the van. Its not in limp mode as it still goes like fook. It has got aircon but makin no difference
Old Mar 7, 2010 | 04:04 PM
cossiegreg1
you need someone with vag-com
Old Mar 7, 2010 | 05:06 PM
krypton's Avatar
krypton
Could be coolant temp sensor thats gone
Old Mar 7, 2010 | 10:08 PM
muttsnutts89
or possibly pressure switch for air con, if detects a faulty high pressure reading wil bring the fans on to try to cool it down.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
Botts
Sep 22, 2015 02:04 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
