04 ST170 - sidelight bulbs
Old Mar 3, 2010 | 05:07 PM
ceejay2626!'s Avatar
ceejay2626!
Default 04 ST170 - sidelight bulbs
how the hell do i change them?
removing the cover off the back of the light unit doesnt givee u any access to them. Surely i dont have to remove the whole light unit do i just to change a couple o bulbs?
i have tried removing the light uinit but i cant. took out the grill and the 2 bolts but it doesnt want to come out? help..
Old Mar 3, 2010 | 05:11 PM
CoupeUK's Avatar
CoupeUK
Bulbs are 501's.
On my old ST170, it was just as easy to remove the lights to do any of the bulbs, mine had 2 bolts but IIRC theres actually 3.
Theres 2 bolts and 2 clips to remove the grille which you'll need to take out to get the lamps out, one bolt on the top of each and one into the wing. Not sure exactly where the 3rd one is buti'll try find out exactly where it is now.
EDIT: Seems like there is another bolt underneath the headlamp apparently, mines never had that one though.
Old Mar 3, 2010 | 05:14 PM
CoupeUK's Avatar
CoupeUK
This may help http://benjol.blogspot.com/2008/08/f...lb-change.html
Old Mar 3, 2010 | 05:16 PM
ceejay2626!
cheers, got the bulbs already.fort it wud be a 2 second job..lol
had the grill off so nowt in the way of the light. 2 bolts i could find r on the top of the light unit (one to the back, one to the side/wing area) couldnt see a 3rd though..
Old Mar 3, 2010 | 05:42 PM
ceejay2626!
cheers for that link , but it dont help....
Old Mar 3, 2010 | 08:12 PM
MisiekT_PL's Avatar
MisiekT_PL
to take out the whole light you must unscrew 2 bolts on top and 1 under the lamp (access from under the car)... but you don't need to - it's possible to replace them without taking out the lamp if you're patient enough
Old May 4, 2010 | 10:54 AM
stu1710's Avatar
stu1710
the 3rd bolts underneath the lamp, next to the bumper.
Old May 4, 2010 | 08:36 PM
Sp3no's Avatar
Sp3no
If you look in the wheel arch where the arch liner meets the front bumper, you will see a torx headed screw that joins the bumper and lower arch liner. Undo this, turn the wheel full lock and pull the arch liner out enough to get your arm in and undo the 3rd bolt
Old May 4, 2010 | 08:46 PM
rsfido_1989's Avatar
rsfido_1989
omfg i gotta do mine, wot a mission it sounds like its gonna be
Old May 5, 2010 | 08:50 PM
TomStarkey's Avatar
TomStarkey
I didn't take any screws/bolts out when I changed my bulbs, I changed them all apart from the indicators. Maybe I'm just able to bend my fingers into positions they're not supposed to bend too.
I just took the box off and flipped the wire clips off and changed the bulbs...
The lights work and no water gets it so I assume I've done noting wrong.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Steve Escos
Oct 1, 2015 06:57 AM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Flatlinedan
Sep 18, 2015 12:41 PM
