Hot starting problems
Old Jan 9, 2005 | 01:56 AM
Gav Diamond's Avatar
Gav Diamond
Default Hot starting problems
Got this really annoying problem
When the car is cold it will start first time, but when it is warm it really struggles to start.
It will normally go second or third time if it will go at all.
I have had the car set up, but no difference.
Its pretty much standard other than a chip.
Tried changing plugs etc but made no difference.
Also if you leave it ticking over for a while it fouls the plugs up and when turned off it wont start at all.
Any help would be apreciated.
Oh and the car is a 88 Escort RS Turbo if that makes any difference.
Old Jan 9, 2005 | 07:49 PM
Big AL's Avatar
Big AL
Mine turned out to be the coilpack.
Old Jan 10, 2005 | 07:03 PM
joo5t's Avatar
joo5t
Default Re:
common problem ?
i have just made a switch on my fan so i can always turn it on when driving fast.
Old Jan 10, 2005 | 08:59 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
starter motor getting too hot?
is it turning over or just dead?
I had an old xr that when it was warm it wudnt start, let the fan cut in then it wud be fine
Old Jan 12, 2005 | 06:32 PM
RS_JAY's Avatar
RS_JAY
Starter motor getting stuck. Mine done it & my old escort done it. common fault as mentioned
Old Jan 13, 2005 | 02:54 AM
Gav Diamond
Forgot to say, starter motor is a brand new diesel one and the car turns over and tries to go but just doesn't go.
It doesn't run a coil pack mate.
Originally Posted by joo5t
common problem ?
Fans work fine mate, also mine are on a switch just incase i get stuck in traffic i can cut them in early
Old Jan 13, 2005 | 08:14 PM
RS_Turbo_Joe's Avatar
RS_Turbo_Joe
i got this problem also on my S2...
starts fine cold once warm'd up wont start again... only if i bump it
gonna get new starter motor and coilpack hope all is better after
Old Jan 14, 2005 | 05:23 PM
Gav Diamond
I don't understand what people are going on about coilpack as they don't run one.
Old Jan 14, 2005 | 08:20 PM
MK5RST's Avatar
MK5RST
As above, they run on a dizzy unless its a fezzy?
Old Jan 14, 2005 | 10:06 PM
radiant red's Avatar
radiant red
as it been set up by somebody who knows what they are doing.
If it keeps fouling plugs up that means it is rich, maybe so rich it finds it hard to fire.
When i first baught my rs it was a pig to start, because it was rich, suppose to have had a so called specialist look at it but he could not find problem.
The problem was the air flow meter position was wrong, it was too far down causing it to overfuel.
Set sensor plate, reset co's ran and started fine.
Old Jan 15, 2005 | 06:58 PM
MK5RST's Avatar
MK5RST
where in wakefield u from radiant red?
Old Jan 31, 2005 | 08:02 PM
series 1 rs cab's Avatar
series 1 rs cab
HAVE HEARD THAT LEAKING INJECTORS CAN ALSO CAUSE HOT STARTING PROBS
Old Feb 2, 2005 | 03:15 AM
Gav Diamond
Cheers guys but i have desided to sell the car as it is as i need the space so i will never find out what is wrong with it.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
