crank position sensor
Old Jan 8, 2005 | 10:48 PM
tommyt's Avatar
tommyt
Default crank position sensor
just wanted to know if i could run the above from my bottom pulley or camshaft pulley (just got a new erst flywheel) or have got to get an efi one any help would be gr8 thanks
Old Jan 9, 2005 | 12:39 PM
sammy's Avatar
sammy
ill guess its an erst going to efi? for fiesta turbo management, it would be easier to use the efi flywheel (i could be wrong but i think you would have to accurately weld 36 lugs on). if its cossy management, you can weld 4 lugs on the front crank pulley & mount a crank pos sensor.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
