cam sensors
Old Mar 2, 2010 | 05:51 PM
morto's Avatar
morto
Default cam sensors
ive spent around 4 hours with a mechanic friend of mine trying to find out why my evo 6 engine is only on 2 pots , the engine management light came on and and the engine died doing around 30mph, we think weve tracked it down to the cam sensor around £60.00 it also could be the crank angle sensor, my question is how does the cam sensor work ? as on my fiesta you can pull the cam sensor off and it will still run?
thanks
andy
Old Mar 2, 2010 | 07:10 PM
thebigyin's Avatar
thebigyin
google, as i cant be arsed typing!!
Old Mar 2, 2010 | 07:17 PM
muttsnutts89's Avatar
muttsnutts89
if the crank sensor was not working it would not run at all so prob not goin to be that.
Old Mar 3, 2010 | 08:37 PM
morto's Avatar
morto
quick update on this guys, my new cam sensor arrived this morn, put the part in and it turned over with no issues at all, so well happy
andy
Old Mar 4, 2010 | 06:18 PM
Most ecu's only look for the phase/cam sensor signal when starting and lock onto it, so unplugging will still run, until you come to start again.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
