poss buying a st220 wot to look for?
Mar 1, 2010 | 09:13 PM
hi im thinking of selling the frs and buying a mondeo st220, are there many common faults with these cars and what to look out for?
any advice would really be appreciated.
thanks kieran
Mar 1, 2010 | 09:16 PM
starter motor went on mine at 40000 cost 280 at ford dealer
outher wise no problems at all smooth motoring m8
Mar 2, 2010 | 09:21 AM
Rear subframe bushes, rust at the bottom of the front doors on the inside. bar that, just the usual things you would look for when looking at any car.
Mar 2, 2010 | 11:49 AM
Look out for petrol stations, you will need them
Mar 2, 2010 | 11:58 AM
Quote:
Originally Posted by
Jasesapphy
This is very true...
If it does bother you, you could look at the ST TDCI, or I believe the titanium x has all the same toys but just not the same looks...?
Mar 2, 2010 | 11:59 AM
Resident Wrestling Legend
arb drop links
4 different ages/specs so make sure you know which version u r going 2 c
Mar 2, 2010 | 12:45 PM
Look for an oily sump, theres been a few instances of leaky rear crank seals and sump seals.
Steve
Mar 6, 2010 | 08:14 AM
kieran265
ok for
Mar 6, 2010 | 10:34 AM
Look for the car next to it as it'll be a better buy if not check out
www.fordmondeo.org
Loads of info in there .
tankybaby66
Feb 6, 2016 02:24 PM
Fil
Sep 30, 2015 12:08 PM
muz
Sep 30, 2015 08:29 AM
Nick 172 Sport
Sep 28, 2015 07:21 PM
