fiesta 1.4 16v r reg non starter
i posted a problem last year still having same problem but worst now .i try to start the car i can hear a noise at the back (fuel pump?)it does not crank and little light on dash flashes rapidly .all other dash lights come on when the car does start it runs fine i was told by a garage that it was a blanket computer problem a would need all electronic parts replacing .at the cost of one thousand pound (are they taking the p)this is a intermitant flault and seems to be bad when weather is cold and damp i have had ecu tested and came back clear i have cleaned all earth wires and any connections i can find .i only have one key with car (black one ) is there a way of bypassing the imobiliser if that is the problem .some one help this car is to good to scrap any cant afford to buy a new one
i have tryed that still there is a problem weather was mild here today just tried it it started it only seems to happen when cold and damp is there some sort of cold sensor that can go wrong
Steve Escos
Oct 1, 2015 06:57 AM
Orion_Gav
Sep 29, 2015 04:50 PM
deathrider666
Sep 28, 2015 06:12 PM
