watch this space
Old Feb 22, 2010 | 09:14 PM
Turbosimpsons's Avatar
Turbosimpsons
Default watch this space
Escort cosworth on it's way:-
m4tt274's Avatar
m4tt274
.. ok
Turbosimpsons
Old Feb 22, 2010 | 10:21 PM
COLEYST200's Avatar
COLEYST200
Very nice but is that all you are going to say
Tell us wot your plans for this shell please and get this rolling
Old Feb 22, 2010 | 10:47 PM
Martin//TwistedTuning's Avatar
Coyote
Escort Cosworth, Nice
Old Feb 23, 2010 | 09:06 AM
declan morris's Avatar
declan morris
ehhh!!!!
Old Feb 23, 2010 | 10:36 AM
Ryan_3's Avatar
Ryan_3
ok...
Old Feb 23, 2010 | 11:02 AM
whittyscossy's Avatar
whittyscossy
Old Feb 23, 2010 | 07:01 PM
Turbosimpsons
ok. this is the plan. it's currently sitting in turbosystems. awaiting some big mods. i goes something like this. ryan loom, p8, wasted spark, gt40, farndon crank and rods, wet linered block, fully ported head, RS500 inlet, 2wd exhaust man. external wastegate,air injectors, pro alloy in car tank with twin submersable pumps, pro alloy intercooler and rad.chassis mods 2wd rear beam, bilstein 2.25" suspension, adjustable rear arms,300mm ap's, 9" diff, tremec 2wd gearbox. front suspension also bilstein, adj. tca's,compression struts, 362mm ap's. wheels. 8.5 x 18 image split rims. trim staying standard except stack dash and pectel monitor
Old Feb 25, 2010 | 08:39 PM
Turbosimpsons
front hub re-drilled and tapped 12mm to take bolts instead of the nuts and bolts supplied (stronger)
Old Feb 25, 2010 | 08:41 PM
Turbosimpsons
caliper mount bolted on.
Old Feb 25, 2010 | 08:46 PM
Turbosimpsons
n/s/f disc and caliper on.
Old Mar 1, 2010 | 07:38 PM
WongRS's Avatar
WongRS
Looking nice mate , them 6 pots are a tad larger than the 4's!
Old Mar 1, 2010 | 10:03 PM
Turbosimpsons
362mm. largest size AP recomend fitting on standard hubs. need good brakes. always helps!!! hows yours cumin on.
Old Mar 2, 2010 | 07:07 AM
WongRS's Avatar
WongRS
its getting there now, just waiting for springs and a few other bits and bobs, MOT time soon.
Old Mar 2, 2010 | 07:20 AM
andy escos's Avatar
andy escos
ill keep an eye on this one
Old Mar 15, 2010 | 10:10 AM
Turbosimpsons
not much happening at the moment. waiting for my loom to be made. also waiting for my wheels to be made. fingers crossed wheels should be nxt week. working on the rear end at the moment. might have dropped on a mag rear end.
Old Mar 18, 2010 | 11:05 PM
Turbosimpsons
been doing some cleaning. from this
to this.
Old Mar 31, 2010 | 08:53 PM
Turbosimpsons
wheels have arrived
1 fitted. just need tyres. can anyone recomend some tyres. 8x18 on front 9x18 on rear
Old Mar 31, 2010 | 08:58 PM
WongRS's Avatar
WongRS
225-40-18 front, something like a 245-35 on the back?
Could go 225 all round, stretch a bit on the back though.
Old Mar 31, 2010 | 09:05 PM
andy130's Avatar
andy130
looks good mate not sure on the rims tho?
Old May 19, 2010 | 08:19 AM
Turbosimpsons
found more goodies.
Old May 19, 2010 | 03:01 PM
m4tt274's Avatar
m4tt274
wow. how much did that set you back! this car looks like its going to be stunning when finished, wheels are to an acquired taste tho
Old May 20, 2010 | 09:36 AM
Turbosimpsons
throw some paint on this.
you can have this.
Old Jun 3, 2010 | 08:09 AM
Turbosimpsons
square beam, mag. arms fitted.
Old Jun 3, 2010 | 08:23 AM
focusjames's Avatar
focusjames
life is good
wow this is gonna be awesome
Old Jun 3, 2010 | 08:52 AM
whizzisat114's Avatar
whizzisat114
liking the rear end
boeb
Jan 9, 2020 05:11 AM
mk22door
23
Oct 2, 2015 10:06 PM
Oct 1, 2015 02:00 PM
